Subject Topic: Noise on 98 Frontier Post ReplyPost New Topic
rener261
Posted: Jan 21 2010 at 10:14am | IP Logged Quote rener261
I have a '98 frontier that has been making a noise when I rev the engine.  When I change gears and let off the gas pedal the sound goes away.  To me it sounds almost like something is vibrating.  The noise is not coming from the actual engine that I can tell but I can here it best from under the truck.  Any Ideas?
Back to Top View rener261's Profile Search for other posts by rener261
davidjbrady
Posted: Jan 21 2010 at 1:44pm | IP Logged Quote davidjbrady
Can you describe the noise? Loose pipe/muffler maybe?
08 Frontier CC, 4X4, LWB
rener261
Posted: Jan 21 2010 at 5:25pm | IP Logged Quote rener261
It's a kind of high pitched whining noise that goes up and
down as I drive through the gears. I was out looking at
the exhaust manifold and noticed a small section that has
possibly rusted through by one the bolts that hold on what
looks like a heat shield over the manifold. It has broken
away in a circle around the bolt. I'm guessing this is the
noise. It's a vibration that I hear.
