Subject Topic: 98 Frontier Idles up and down Post ReplyPost New Topic
agreencompanync
U.S. - North Carolina
Posted: Jan 21 2010 at 7:52am | IP Logged Quote agreencompanync
Truck when idling will jump from 500 rpm to about 1800 rpm, and will continue to do this until you put it in gear and drive away, but when you come to the next stop it will do the same thing.  Thanks for your help
Back to Top View agreencompanync's Profile Search for other posts by agreencompanync
davidjbrady
Posted: Jan 21 2010 at 8:14am | IP Logged Quote davidjbrady
What year and what engine are we talking about here?
Have you cleaned the throttle plate?
08 Frontier CC, 4X4, LWB
agreencompanync
Posted: Jan 21 2010 at 2:13pm | IP Logged Quote agreencompanync
1998 Frontier with the 4 cylinder engine.  I have not cleaned the throttle plate
Posted: Jan 21 2010 at 6:32pm | IP Logged Quote frontierguy
Does it have an aftermarket air filter or GENUINE NISSAN oil impregnated air filter??? Any dirt/debris in the hole going to the MAFS fine wires?? Clean and tighten all engine grounds, as already mentioned -clean throttle bore and blade- perform idle adjustment as per service manual.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
agreencompanync
Posted: Jan 21 2010 at 7:45pm | IP Logged Quote agreencompanync
It's a genuine nissan filter...there doesn't appear to be anything inside the maf hole.
