Subject Topic: noise in rear of truck Post ReplyPost New Topic
Hinkle
U.S. - West Virginia
Posted: Jan 12 2010 at 4:32pm | IP Logged Quote Hinkle
I have a 2007 Nissan Frontier Club Cab with 4.0 liter engine and automatic transmission. I have a noise in the rear of the truck that sounds like slack in drivetrain. to me it sounds like the rear end has slack in it or the driveshaft is moving up and down. Because of the weather I can't get under it right now. Has anyone had the same problem. Any Idea's. Thank you
Praise Jesus
Back to Top View Hinkle's Profile Search for other posts by Hinkle Visit Hinkle's Homepage
Posted: Jan 12 2010 at 7:30pm | IP Logged Quote frontierguy
Is this something you just noticed or has it always done it? How does the fluid look, any moisture in it? Also check the vent to see if the cap is free(not stuck due to rust intrusion). These rear diffs do have quite a bit of excessive play in them.< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
Hinkle
Posted: Jan 13 2010 at 12:06pm | IP Logged Quote Hinkle
I bought the truck used, it had only 12,000 miles on it and I have had it about two months. So I only know it has done it since I bought it. I get off and back on the gas in traffic I can here a clunk like there is slack in it. It has been snowing here for 4 weeks off and on and I don't have a place to get under it and check anything out right now. I soon as I can I'll try. Thanks for the tips, i'll check them. I just thought some who have owned there's for a while may know the problems. It might be a common problem..
Praise Jesus
Boomer
Posted: Jan 13 2010 at 1:28pm | IP Logged Quote Boomer
I get a mild version of this in my 2007 depending on how I get on and off the gas.  Usually just indicates some play between the ring and pinion gears.
2007 Nissan Frontier SE 4X4
Hinkle
Posted: Jan 13 2010 at 2:40pm | IP Logged Quote Hinkle
I thought that was probably my problem, since I haven't had it that long I really haven't had a chance to check it out. If the weather breaks I'll try. Thank you for the info.
Praise Jesus
