Subject Topic: 4x4 noise Post ReplyPost New Topic
raven18330
Posted: Dec 08 2009 at 3:12pm | IP Logged Quote raven18330
I have had my 2006 Nismo for about a week now. Yesterday i started to notice a lot of noise from the front end. Starts out clicking at low speeds, then turns into a louder noise @ high speed. Maybe a wheel bearing or cv axel? any suggestions would be apprecieated.
Back to Top View raven18330's Profile Search for other posts by raven18330
Posted: Dec 08 2009 at 7:58pm | IP Logged Quote frontierguy
Check the u-joints on the driveshaft, axle boots for rips and grease leakage, wheel bearings for loosenes(seen them noisy and not loose!!!)< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
raven18330
Posted: Dec 08 2009 at 8:01pm | IP Logged Quote raven18330
thanks for the reply. to provide more information on the problem, the best way that i can describe the sound is that it sounds like a baseball card in a bicycle spoke when at low speeds. the noise stops when 4wd is engaged.
raven18330
Posted: Dec 10 2009 at 12:46pm | IP Logged Quote raven18330
Good call Frontierguy, was the u-joint. Thanks for the help. many props.
