Subject Topic: 98 frontier gauges not working Post ReplyPost New Topic
RBlanton
Posted: Nov 12 2009 at 7:43am | IP Logged Quote RBlanton
I have a 98 frontier that the gas gauge and any other gauge on the dash does not work. sometimes they work and go back off.  the temp gauge and odometer does not work either nothing on the dash works properly.
Back to Top View RBlanton's Profile Search for other posts by RBlanton
Posted: Nov 12 2009 at 7:44pm | IP Logged Quote frontierguy
Remove the meter assembly, tighten all the screws on the printed circuit board. Tighten the grounds behind the right and left kick panels. If that doesn't help, most likely it will need a Unified Meter Control Unit(speedo assy).
BRIAN Rush
Posted: Dec 06 2009 at 3:33pm | IP Logged Quote BRIAN Rush
having some problems with dash lights not going off with key turned off
any ideas
BRIAN FF
Back to Top View BRIAN Rush's Profile Search for other posts by BRIAN Rush
