bross Newbie
Posted: Oct 20 2009 at 3:19pm | IP Logged
I was going to change the differential oil and transfer case but can't find the capacity listed anywhere, in my manual, my Haynes service manual or here? Just wondering how many quarts of oil I need to order. I don't think the differentials will even use a quart will they? I have 80W90 for the front but need to order some 75W140 for the rear and not sure if I'll need more than one quart.
I see the transfer case uses 2l of ATF but just found it weird that no capacity was listed for either differential.
bross Newbie
Posted: Oct 20 2009 at 3:26pm | IP Logged
Nevermind, just found the capacities on the Amsoil website, thanks.
CAPACITIES:
Engine, with filter..........5.1 liters [1] Cooling System, Initial Fill..........10.2 liters AMSOIL Antifreeze and Engine Coolant Automatic Transmission, 5 Speed Initial Fill..........Not Specified Automatic Transmission, Total Fill 5 speed 5 Speed..........10.3 liters Manual Transmission, 6 SPD 4x4..........4.2 liters Manual Transmission, 6-SPD 4x2..........4 liters Differential, Front..........0.9 liters Differential, C200 Rear..........1.6 liters Differential, M226 Rear..........2 liters Transfer Case, ..........2 liters
Posted: Oct 20 2009 at 7:45pm | IP Logged
For future reference, it is helpful to know what you are working on!!!!
