Subject Topic: Help with brakes Post ReplyPost New Topic
Screech
Posted: Oct 12 2009 at 8:30pm | IP Logged Quote Screech
I have 2000 frontier with a v6 2wd and abs.  I had a piston in the right front caliper crack and leal fluid everywhere, so I replaced that, bled the brakes and could never get a brake pedal it would just keep sinking no matter how I bled it.  So I replaced it with a new one from the dealer and it still acts the same.  I took it to a mechanic to take a second look and he bled the brakes and still the same.  So he told me to take it to the dealer to have the brakes power bled.  So I did and they told me that the caliper I just replaced was bad, so I got another one, bled the brakes and I still have a extremely low pedal and I can hit the floor if i push hard but it will stop.  Im out of ideas and any help would be appreicated.   Thanx
Back to Top View Screech's Profile Search for other posts by Screech
Posted: Oct 19 2009 at 8:39pm | IP Logged Quote frontierguy
Bleeding procedure is as follows: LSV(load sensing valve) -LR -RR - LF - RF - ABS Actuator, in that order. If the system went dry, bleed the master cylinder first.
