Subject Topic: lights on trailer don’t work Post ReplyPost New Topic
craigs449
Posted: May 16 2009 at 9:08pm | IP Logged Quote craigs449
Help, I just got a U-haul hitch installed on my 2008 Nissan Frontier.  Hooked up my trailer today and checked the lights.  They worked fine.  Drove down the road and used my signals but they only blinked once!  Nothing worked afetr that.  I stopped and disconnected the lights and re-connected them again.  They worked properly on the truck and trailer for that first attempt only!!!!  After I shut off the signals, the lights would only blink once...  Thare has got to be some type of relay that someone on here knows about that I have no Idea of....Please help!!!!!
Back to Top View craigs449's Profile Search for other posts by craigs449
Posted: May 17 2009 at 9:26pm | IP Logged Quote frontierguy
Did U-haul install the harness also????? If so, remove it and install a Nissan harness which goes behind the RF kick panel with 2 relays for auto or 3 relays for man trans models. If they installed the harness in the back, it's most likely hacked in with scotch locks or some other crap -Nissan harness plugs into 2 connectors in the LR frame rail.
Seen nothing but problems with aftermarket trailer harness installations!!!!!
craigs449
Posted: May 18 2009 at 8:19pm | IP Logged Quote craigs449
yup, they did their wiring harness.  i'll stop by the nissan dealer and get a trailer wiring harness...thanks for the response!
fpe5
Posted: May 21 2009 at 10:06am | IP Logged Quote fpe5
I'm having the same problem with my 08 and uhaul also installed it. had to order a t connector with the relay because uhaul hard wired it
Back to Top View fpe5's Profile Search for other posts by fpe5
craigs449
Posted: May 29 2009 at 3:17pm | IP Logged Quote craigs449
Where did you get the "T" connector from?  Is U-haul gonna install it?
airah18
Posted: Nov 09 2010 at 7:48pm | IP Logged Quote airah18
Try to recheck all your fuses. You either have old bad bulbs somewhere in your trailer or a little short circuit. If you cannot find where is wrong, try to ask professional help from expert people.
cargo trailers
Back to Top View airah18's Profile Search for other posts by airah18
MWD7
Posted: Dec 31 2010 at 10:42pm | IP Logged Quote MWD7
If you're not using a plug-n-play harness (like the one available from Nissan), you're asking for problems. Scotch-locks are worthless, and if they cut & spliced the wires, make sure they are sealed properly (with heat shrink, not electrical tape) and that they ran a proper ground (normaly white) wire.
Back to Top View MWD7's Profile Search for other posts by MWD7
