Posted: Nov 16 2008 at 6:08pm | IP Logged
Jwild32 wrote:
for some reason my airbag light is just a flashing away. Any clue on how to get that thing to stop, aka reset the sensor, without bringing it in to the dealer?
Hey, I had the same problem after I installed my stereo system, easy fix for us first gens.
it took a bit of research, but this worked on my 03 4x4 XE
Turn key to on (don't start) Watch the air bag light, once it disappears, immediately turn off (leave key in ignition) (Also, if it blinks, start over) Once in the off position, count to 5 (one one thousand, two one thousand, etc) Turn key to on (again, same procedure as before) wait for the air bag light to disappear and then turn back to the off position and count to 5 again, perform this procedure 3x. Remove key, turn truck on, and voila, all gone. (worked for me anyway)
