Subject Topic: something in the fan under glove box Post ReplyPost New Topic
allenh
Posted: Nov 10 2008 at 2:36pm | IP Logged Quote allenh
Has anyone had something caught in the fan under the glove box?  It sounds like a piece of paper or leaf is stuck in there and hitting against the fan blades.  I can't see it, as there's a cover on the fan but it speeds up and down as I adjust the air conditioner/heating fan speed.
If so, what did you do to resolve?
Back to Top View allenh's Profile Search for other posts by allenh
Posted: Nov 10 2008 at 8:16pm | IP Logged Quote frontierguy
Unplug it, take the 3 screws out to remove and inspect it. Hopefully not a dead mouse!!!!!!!!!!!!!!!!!!!
allenh
Posted: Nov 12 2008 at 11:14am | IP Logged Quote allenh
Thanks Frontier guy.  Have you done this?  How difficult/time consuming?
Posted: Nov 12 2008 at 5:17pm | IP Logged Quote frontierguy
Many times. As mentioned before, it helps to know the particular vehicle you are referring to, maybe add it to your signature!!!! Assuming it is an 05 or later Frontier, you will need to remove the sill plate and kick panel - they basically are held on by push clips. Unplug connector to the motor, then remove the 3 screws.
allenh
Posted: Nov 13 2008 at 11:44am | IP Logged Quote allenh
Many thanks, yes, it's an 07 frontier.
