Subject Topic: Passenger Door will not unlock Post ReplyPost New Topic
mbarr69
Posted: Aug 04 2008 at 10:03am | IP Logged Quote mbarr69
  Looking for a little help here actually looking for a diagram of a 2001 Frontier automatic door lock setup. I'm not looking for a wiring diagram. My passenger side door will not unlock. When I flip the switch to unlock the door I hear the motor making a funny noise. I think the motor is ok I think it is just a rod or something not lining up to unlock the door and the motor is straining. I can't open my door to take the panel off to look at the problem. Anyone know a way to get the door open if this happens? Any thought or comments are appreciated.
Thank you!
Back to Top View mbarr69's Profile Search for other posts by mbarr69
Posted: Aug 04 2008 at 3:38pm | IP Logged Quote lakota
mbarr69;
Have you tried the remote unlock. There is a weird combo of locking with the remote then unlocking from the inside that caused me a problem years ago. Might try leaning on the door to close it tighter then unlock it. Let an old cop or crook try it...
My passenger door still has a standard key-lockset. I notice mant new vehicles don't.
If something I’ve posted on the Internet warps your thinking please ignore it. If you don’t know how to ignore something on the Internet e-mail me and I’ll demonstrate!
iis4isaac
Posted: Aug 06 2008 at 8:35am | IP Logged Quote iis4isaac
Usually, even if the lock is an automatic lock, it relies on a motor and mechanical arm to lock/unlock the latch.
If you've got a frontier, why haven't you downloaded the factory service manual yet?  there's a stick for it in this forum.  Here's the link.
http://phatg20.info/index.php?option=com_remository&Item id=26&func=select&id=1
Go there, get your FSM, look up the diagram on the door panel removal and lock diagram.
Hope that helps.
2000 Nissan Fronter Crewcab
V6 3.3L
Solar Yellow - the only way to fly.
Back to Top View iis4isaac's Profile Search for other posts by iis4isaac Visit iis4isaac's Homepage
