Subject Topic: Driveline Slack Post ReplyPost New Topic
lenaitch
Canada
Posted: Jun 18 2008 at 8:39pm | IP Logged Quote lenaitch
New to the forum so here goes.  I've had my 08 SE V6 4x4 since December and only just over 3000 miles (5000 km up here) on it.  So far so good and generally pleased.  No numbers yet but perception is much better fuel consumption than my 99 V8 Dakota.  The one thing I do notice is a significant driveline lash in the 30-50 MPH range - it clunks a lot when the power comes on and off, like in traffic.  It is especially noticeable when coming down from higher speeds and I'm guessing it's still in 5th/OD.  The dealer said this is normal and caused by the 4x4 drivetrain.  I'm on my 6th 4x4 and none have done it.  Any similar observations?
Also, I'm thinking of installing a K&N air filter (just the replacement element, not the full modified intake kit - I'm way too cheap).  Any experiences?
Tnx
Midland Ont. Canada
08 SE King Cab V6 4x4
10 Hyundai Tucson
12 HD ElectraGlide
Back to Top View lenaitch's Profile Search for other posts by lenaitch
fallowme
Canada
Posted: Jun 30 2008 at 9:15pm | IP Logged Quote fallowme
my truck does that, its annoying,  it has made me nervous in the past but it hasn't blown up yet. i had the k&n filter before the nismo intake, changed the sound a little, little better on gas, untill you start hitting the gas to hear the sound. your probably thinking do that, but you will
2005 nimso c/c 4x4, prg lift, 33" prcomp extreme at, procomp wheels, 3"gibson ehxaust, nismo type R intake, uprev,
Back to Top View fallowme's Profile Search for other posts by fallowme
Posted: Jun 30 2008 at 11:45pm | IP Logged Quote lakota
Here is a link to links about clunks and noises.
http://www.nissanfrontier.org/search.asp?KW=clunk+noise& SM=1&SI=PT&FM=3&OB=1
medicchief
U.S. - Arkansas
Posted: Oct 06 2008 at 7:38pm | IP Logged Quote medicchief
I have a 2008 Frontier V6 4X2 and it does these same thing, "clunk".  I find it very annoying, not something I expected from a new vehicle with only 6k miles.  Passengers also ask me if the rearend is going out or what the problem is.  Most posts I have read refer to 4X4's, does the same "fix" apply to 4X2's also?  I did put a K&N filter in it, but really didn't notice any difference in performance or MPG.  Currently gets 20 MPG average.
Medicchief
Back to Top View medicchief's Profile Search for other posts by medicchief
hsckris
U.S. - North Carolina
Posted: Oct 07 2008 at 11:04am | IP Logged Quote hsckris
I had this problem when my truck had that few miles... it now no longer does it/doesn't have this problem and hasn't for awhile.  I honestly think everything is so tight in there it is just seating in, though I don't know for sure.
 My truck has ~36k on it now, and it hasn't done that since probably around 10-12k or so.  Also, I learned to sort of drive around it -- drive in a way that makes the truck do that less.  And then it went away.
Nissan checked my entire truck out around that time frame (for other reasons) and nothing was wrong, so I'm assuming its fine.  I haven't had any problems.
06 Nissan Frontier KC SE 4x4.
03 Ford Focus ZX3.
