Frontyfan Senior Member
Posted: May 26 2008 at 2:22pm | IP Logged
The only place I could direct you, is to maybe see if you can take it apart, the assembly, if you can remove the whole plastic thing, then maybe you could find a replacement as a junkyard that's not in too bad of shape if you clean it up a little like a pick-n-pull. Or there is always the dealer to get information and see how much they want for it. Hopefully it won't take replaceing the whole tailgate.
