LarryJ Newbie
Posted: Oct 05 2005 at 12:23pm | IP Logged
..if so then where did you find the sub harnase to plug the relays into? I have the instructions but they are unclear as to where behind the passenger side kickplace the connector is hidden. Thanks in advance, Larry
__________________ 2005 Nismo Frontier
LarryJ Newbie
Posted: Oct 05 2005 at 6:06pm | IP Logged
I finally found it. The connector was taped behind the bracket and I could touch it but couldn't see it. It is there but just hard to find.
AZLS1 Groupie
Online Status: Offline Posts: 43
Posted: Oct 06 2005 at 11:46am | IP Logged
Good info thank you for posting the follow up.
