Posted: Mar 07 2008 at 1:23pm | IP Logged
another thing to keep in mind, and I have noticed will all the nissans i have driven..when a cold start is executed. the chokes on these computer controlled motors will have the rpms run up to about 2000-2500k and then drop back down, sometimes lower, part of it is due to oil pressure as well i would guess until it stabilizes you will also notice that as your engine gets warm, the idling rpm will drop to under 1000k, on my SE 3.3, it'll be around 600. if you had an auto tranny, you'd also notice that until the tranny gets warm, the torque converter won't lock up, and until that happens i run around 2000 rpms around 45 mph, after it does..the rpms drop by a few hundred. all this says is that until this happens, in theory i'll be using more gas until my engine/tranny is warm, because the choke/torque converter need time to let things to get to operating them.
the rpm gauge, could be out of cal, are you having rough idling?
