penaltybox1 Newbie
Posted: Feb 05 2008 at 7:54am | IP Logged
Does not matter f selector is in defrost, floor, bilevel, vent anytime the fan is on the compressor is on. A/C switch seems to do nothing except lite up if pushed on. Any clues????
Posted: Feb 05 2008 at 5:49pm | IP Logged
Modern vehicles automaticly turn on the A/C in the defrost possition to help dry out the air to clean the glass quicker. they hook it up that way because we are to stupid to do it. It's just another way to waste gasoline!
I don’t use the defroster very much. What really hacks me off is adding heat to the A/C! We noticed in our 95 Quest, ’95 King Cab and ‘99 Frontier heat was flowing automatically when the A/C was running, how stupid is that?… I’m using extra fuel to cool the vehicle and the system is adding heat to it! Many other brands besides Nissan are doing this. I don’t know the answer to your question but here’s what I do to reduce the problem. I run the A/C wide open (max cold) and manually turn the compressor on and off. I turn the compressor off going up-hill and on during the down hill run… This seems to conserve power, fuel and seems to stop the heat flow.
I’ve thought about putting a adding a separate on/off switch to the compressor but worry that it might confuse the trucks computer causing it to go into self destruct mode!
Laws such as the use of corn ethanol are driving up the cost of living (have you been to the grocery store lately) without driving up wages. This equates to a lower standard of living thanks to Agro-lobbyists and corrupt and/or ill-informed lawmakers.
penaltybox1 Newbie
Posted: Feb 05 2008 at 10:20pm | IP Logged
I guess you don't understand , there is no off to the compressor if the fan is on so is the compressor . So not to be rude but if you can't understand what I'm saying don't reply .I know about the "design"for the auto defrost . This is not that, it's that it runs all the time
Posted: Feb 05 2008 at 11:30pm | IP Logged
penaltybox1 wrote:
I guess you don't understand , there is no off to the compressor if the fan is on so is the compressor . So not to be rude but if you can't understand what I'm saying don't reply .I know about the "design"for the auto defrost . This is not that, it's that it runs all the time  |
penaltybox1;
OK now I understand.. "Does not matter f selector is in defrost" had me confused. Plus no idea which model it is. Is it still in warrantee?
Our volunteer Resident tech- moderator is out of pocket. But I still like “I’ve thought about putting a adding a separate on/off switch to the compressor but worry that it might confuse the trucks computer causing it to go into self destruct mode!"
I am not a tech... but i am a moderator.
Maxbaby Newbie
Posted: Feb 07 2008 at 10:10pm | IP Logged
penaltybox1 wrote:
So not to be rude but if you can't understand what I'm saying don't reply . |
Umm... "not to be rude" but, the whole point of a forum such as this to to try to help someone. The problem didn't start with Lakota's response, it was in your original post. It was too brief, and when I read it the first time, I didn't quite understand what you were saying. Please don't respond with things like "don't reply", at least not around here. The fault wasn't Lakota's. Responses like that might make someone who would have helped you that much less likely to respond.
__________________ 2004 XE Crewcab 4X4
2002 Hyundai Santa Fe
1993 Volvo 850 GLT
penaltybox1 Newbie
Posted: Feb 08 2008 at 1:20am | IP Logged
Well like the original post stated if you read it ,is very detailed there's not much else to say and if you don't understand what I said then you obviously could not help anyway so S.T.F.U. do you me to explain that too !!!!!!!!!
DarrenC Groupie
Online Status: Offline Posts: 46
Posted: Feb 08 2008 at 11:01am | IP Logged
A little punctuation and spell check would have helped the first post too.
__________________ 2007 Nissan Frontier SE 2WD Crew
2005 Specialized Stumpjumper Expert
2003 Honda VFR800 Interceptor
Maxbaby Newbie
Posted: Feb 08 2008 at 5:27pm | IP Logged
penaltybox1 wrote:
Well like the original post stated if you read it ,is very detailed there's not much else to say and if you don't understand what I said then you obviously could not help anyway so S.T.F.U. do you me to explain that too !!!!!!!!! |
Nice... that'll motivate people to want to help you.
1993 Volvo 850 GLT
penaltybox1 Newbie
Posted: Feb 08 2008 at 11:34pm | IP Logged
Well, you are right, but unfortunately I don't give a f___ and it seems like all these forums are by a bunch of bored adolesence that do not know how to fix jack soooo what's the difference !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted: Feb 08 2008 at 11:49pm | IP Logged
penaltybox1;
We may not know jack... but we try to contribute and try to be civil about it. I think it's about time for you to go and join up at Pirate 4x4... they will enjoy having you.
Someone here may have had the answer but not want to put up with you. If you noticed I moderated one of your posts so you wouldn't seem quite so obnocious.
Have a good one.. Don S..
