Subject Topic: Crooked Truck Post ReplyPost New Topic
baltoguy
Posted: Sep 11 2007 at 10:43pm | IP Logged Quote baltoguy
Ok this is weird.  I have a new SE Crew Cab LB.   My steering wheel is still not level when going straight down a flat road (leans to the left about 3/4 inch).  I don't notice any pull (i.e. it seems to go straight just steering wheel is off).  Took it back to the dealer twice and they said they checked the alignment and tried fixing but I didn't notice any change.  I'll probably try another dealer next.
Also, when parking the truck I noticed it always looks crooked in the parking spot compared to the lines no matter how hard I try to park straight.  I tried parking several times in my driveway as straight as possible and measured from the sides of the driveway (concrete - one side is against my house so I feel pretty sure it is straight) and I'm always coming up an with about an inch or slightly more difference from the side of the driveway from front tire to back tire.  So the truck looks like this like it is parked like this (exaggerated): / (front tires slightly to the right of rear tires)
Any idea what is going on?  If so, how do I tell the dealer it is a problem and not get a look like I am insane?  Or should I just get rid of this truck?
Thanks
07 Crew Cab SE 4x4 Long Bed
Back to Top View baltoguy's Profile Search for other posts by baltoguy
bckazoo
Posted: Sep 13 2007 at 9:17pm | IP Logged Quote bckazoo
FYI
I noticed when I first bought my 05 Frontier King Cab that I was getting chips in the paint on the left side only. I took it back to dealership thinking that the mudflap was not properly installed. We noticed instead, that the front left tire was sticking out beyond the mudflap, whereas, the right tire was within the mudflaps range for catching debris. You may want to check to see if this may be causing your problem. Nothing was done for me, and I now carry touch up paint for the chips.
Back to Top View bckazoo's Profile Search for other posts by bckazoo
barberian6
Posted: Mar 03 2008 at 10:48am | IP Logged Quote barberian6
My nissan leans to the Left front view, It is obvious, and I don't know what
the problem might be. it has 35000 and It should not be crapping out this
soon, I drive it like a baby.
You aren't alone, i see the same on some others in the street. Apparently
it is a common problem.
2004 Frontier
XEV6 Stick
2WD
Crew Cab
Back to Top View barberian6's Profile Search for other posts by barberian6
Posted: Mar 03 2008 at 4:31pm | IP Logged Quote lakota
barberian6;
If your Frontier has a torsion bar front suspention you can crank the one on the low side up to match the other side.
My was equil but I cranked both sides up 5/8th inch for a little lift.
At my age my learning curve has degraded to a straight line<snif> <snif> …
drod
Posted: Mar 06 2008 at 6:43pm | IP Logged Quote drod
idk,but maybe you blew out a shock?If not do what lakota said...it worked for me.
Back to Top View drod's Profile Search for other posts by drod
hsckris
U.S. - North Carolina
Posted: Mar 07 2008 at 10:50am | IP Logged Quote hsckris
If it is an 05+, it doesn't have a torsion bar suspension.
Your steering wheel will not necessarily be straight... rather your truck can be straight and your steering wheel not.
What you should do is park it on a level surface (check this with a level).  Then put a level on various places on your truck, both front to back and side to side.  If its not level, you should inspect:
  1. Tire wear & pressure
  2. Suspension & shocks
  3. Weight in the vehicle
The only other thing I can think of is that it is possible something is bent/out of square on the frame.  You would feel that when driving however (at least I did on my prior truck when it had a bent frame).
06 Nissan Frontier KC SE 4x4.
03 Ford Focus ZX3.
