Posted: May 22 2007 at 11:50am | IP Logged
Hello All,
The driver side power window on my 2001 Crewcab is stuck in the up position. I noticed there was a TSB on this but the dealer fix expired Dec 2005. I wanted to replace it myself, but my situation is I'm not sure if its the switch , motor or the window regulator. Also, Is there a "manual" override to roll down the window ? I opened up the door panel hoping there's some kind of "nut" i can turn to lower the track that the glass sits on. Any help/advice would be greatly appreciated.
