Subject Topic: tranny swap Post ReplyPost New Topic
ramjet
Posted: May 02 2007 at 2:22am | IP Logged Quote ramjet
I have a '03 XE crewcab with a 5-speed manual transmission. I like the truck, but I only get about 18.0 mpg. The truck is low geared. When I'm doing 70 mph, the engine is turning 3000 rpm's. I'd like to get the rpm's down to about 2000 rpm.
Will a 6-speed manual from a newer frontier help me and will it bolt up and fit without any modifications?
Back to Top View ramjet's Profile Search for other posts by ramjet
Posted: May 02 2007 at 2:10pm | IP Logged Quote lakota
ramjet;
Welcome to the group!
I’m going to guess you have a 2WD Frontier. It woulds be cheaper to try a pair of larger tires on the rear to reduce RPM. I’ve Done this. My ‘76 Wagoneer wheels will bolt onto ‘04 and older Nissans and Datsuns. If your close to Fort Worth you can try out a pair of my 30” or 31” BFG Ats.
Corn Ethanol: Our government is hoodwinking Americans and making a few people rich. We have a 50 cent per gallon tariff against import ethanol and subside our ethanol refiners 54 cents per gallon with our tax dollars. And the Corn Ethanol will drive food prices up!
hintonl
Posted: May 04 2007 at 11:08am | IP Logged Quote hintonl
I have an 00 auto transmission for sale 60k miles on it willing to sell for 450.00 Should be a strait bolt up  all you would need is the auto trans computer
2K Crew Cab Converted to 4X4
Mainerunr
U.S. - Maine
Posted: May 09 2007 at 10:59pm | IP Logged Quote Mainerunr
What you really need is different gears in the rear end, no need to swap the tranny.  my '97 D21 used to tach high too but it had 4.56 (I think) gears, if it had 3.69's like my '05 has it would have been better.
putting bigger tires on will reduce your rpm but it will likely not improve your fuel mileage and going up 2" in tire size is probably only going to lower your rpm by 7%...
Back to Top View Mainerunr's Profile Search for other posts by Mainerunr
gmw468
Posted: May 17 2007 at 9:29pm | IP Logged Quote gmw468
I've got an 03 Crew cab 4X4 with a 5 speed stick. Yes these trucks are geared WAY too high or too low depending on how you see it. My truck has 4:33 gears (from the factory) and in 5th gear at 65-70MPH, I am taching out at just a hair over 3000 RPM. It's not long trip friendly. I love the truck but when we take long trips we use my wife's Honda Pilot.
In my opinion Nissan screwed the pooch with this one. They should have used lower gears, or added an extra gear to the tranny. You're 100% correct on long trips my truck gets horrible gas mileage. Changing the gears is a costly option. My truck is 4X4 and I'd have to change both front and rear gears. That could cost a fortune.
I'm going to be due for new tires before next winter and I'll be stepping up to 31's. Hopefully that will help a little bit. I don't do a lot of highway driving but when I do I hate to cruise at 3100 RPM.
Back to Top View gmw468's Profile Search for other posts by gmw468
hintonl
Posted: May 18 2007 at 10:30am | IP Logged Quote hintonl
Go to the junk yard or Here www.car-part.com look up an 03 Xterra SE front diff and rear 4.9 gears. This will be a strait up bolt in thing you dont have to set up gears or anything like that .
ramjet
Posted: May 19 2007 at 2:31am | IP Logged Quote ramjet
Thanks for all your help everyone. I don't know what I'm going to do yet. Heck, I may go to the local dealership and buy a new one. I hear the frontier's have more horsepower and a 6-speed transmission.
gmw468
Posted: May 19 2007 at 8:44am | IP Logged Quote gmw468
Yeah but if you bolt in a rear with 4.9 gears it will tach out even higher. In order to lower RPM he'd need to go to something like 3:55 gears.
I can live with it. I only live 4 miles from home. My 03 only has 23,000 miles on it and I own it. The truck does tow my bass boat nicely. So I can live with the bad highway mileage from time to time.
Mainerunr
U.S. - Maine
Posted: May 19 2007 at 7:50pm | IP Logged Quote Mainerunr
way more power and the 6-spd is nice, trust me.  still, dont expect miracles, it's also a larger truck that weighs more.  best tank I've ever had in my '05 is 22mpg (all highway carrying 40 cu ft of mulch) and I'm averaging 18.7 since I got the truck (36k miles so far).
Still, better mpg than my '97 D21 got, twice the power and room for car seats, I cant complain.
BlueCrew
Posted: May 24 2007 at 3:50pm | IP Logged Quote BlueCrew
Back to Top View BlueCrew's Profile Search for other posts by BlueCrew
