Subject Topic: 100,000 mile service Post ReplyPost New Topic
jus104
Posted: Feb 21 2007 at 3:42pm | IP Logged Quote jus104
I'm coming up on my 100,000 mile service and I'm looking for some suggestions on what to replace/change without spending $1,000 at the dealership. Also, is it necessary to change the timing belt, and/or has anyone had problems with this breaking?
01 SE V6 Crew Cab 4x4 Auto
Back to Top View jus104's Profile Search for other posts by jus104
hintonl
Posted: Feb 21 2007 at 9:05pm | IP Logged Quote hintonl
It would be a good idea to do the timming belt along with this list.I had a friend wait till 105000 the belt sliped he now needs a motor here you go
1 timming belt and adjuster/spring and stud
2 water pump and T-stat all rubber hoses even the ones under the upper intake manifold
3 cam seals  and front crank seal
4 all drive belts also
This will set you back some $$ but if you can do the work your self it will save you a ton of money on labor on labor at the dealer ship. Here is a place you can get a copy of the factor service manual pay the 20.00 and down load the manual for your truck save it as a PDF
http://www.nissan-techinfo.com/
on line parts places that I have ordered from that are pretty good
http://www.trademotion.com/partlocator/index.cfm?siteid=49&a mp;catalogid=0
 http://www.courtesyparts.com/betasite/
Hope this helps
2K Crew Cab Converted to 4X4
