fishoholic Newbie
Posted: Feb 06 2007 at 2:49pm | IP Logged
Nope, its most definitely coming from the front bay. I also have a friend with the same problem except his truck is a 2001 I believe, he's tried everything also.
Recently I tried tightening the belts alittle and popped a Heavy Duty battery in. This has seemed to fix the problem so I thought. In the last 5 weeks since the work was done it seems like its beginning to squeel again, but this time its quick and only for a moment. I was also told this could be the bearing in the Fan, which on Nissans, is going steady. Apparently there is an upgrade out there to replace the van with an alternative system. Also I was told it could have something to do with the power steering?
__________________ If it ain't dirty and in the bush, buy a car!
1999 Fronty SE
