Subject Topic: Horn is Stuck Post ReplyPost New Topic
PaperBoy
U.S. - Kentucky
Posted: Jan 09 2007 at 1:49pm | IP Logged Quote PaperBoy
Has anyone experienced a stuck horn on the Frontier?   I have a 98 XE .  The horn will come on and stay on for no apparent reason.   The horn relay is ok. It seems to be a "Ground" problem in the steering column.
Back to Top View PaperBoy's Profile Search for other posts by PaperBoy
Posted: Jan 09 2007 at 8:32pm | IP Logged Quote kcidmil
could be a bad contact ring.  Or horn button is bad and is grounding out.
fishmonger
U.S. - Colorado
Posted: Jan 13 2007 at 5:20am | IP Logged Quote fishmonger
I had a large iron/steel weight come loose inside the steering wheel.  It was part of the air bag unit.  It would tumble around and complete the circut for the horn.  A loose screw or nut would do the same thing.  Previous owner had very bad driving habits including the wreck before I got the truck.  (he stuffed the tickets under the seat, they did not go away)  The part came loose a few months after I got the truck.  I followed the air bag warning info and removed the cover for the wheel, reglued the part and problem was solved.
Back to Top View fishmonger's Profile Search for other posts by fishmonger
