Frontier Towing / Hauling
Subject Topic: Transmission temperature gauge Post ReplyPost New Topic
sundug
Posted: Jan 07 2014 at 8:15am | IP Logged Quote sundug
Can anyone tell me where to install the sending unit for an
transmission temperature gauge on my 2010 Frontier with 5
speed automatic, 4 cylinder? Thanks, Sundug
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
Back to Top View sundug's Profile Search for other posts by sundug Visit sundug's Homepage
Posted: Jan 07 2014 at 10:02pm | IP Logged Quote lakota
Welcome to the group...
I have not been under a truck like yours but in general
look for the hottest of the two cooling lines between the
radiator and the transmission. Install a Tee fitting and
sensor on the hot output line at the transmission. Also,
if your going to pull a heavy load install an auxiliary
tranny cooler while your at it. It can save you a lot of
money later!
Good Luck.. Don S..
