Frontier Towing / Hauling
Subject Topic: Bumper towing Post ReplyPost New Topic
zeeker13
Posted: Apr 13 2008 at 2:13pm | IP Logged Quote zeeker13
I have a question...I have a 2002 Frontier xe 2.4l.  I need to tow a small trailer about 150 miles, the dry wieght is 1750lbs.  I was going through my owners manual and the weight max is 3001lbs.  I should be good as far as not exceeding the weight, but wanted to know the capisity of the bumper hitch.  I was going to attach the tow ball to the hole provided.  I would like to avoid buying a class 3 hitch.  I looked under the body and the bumper seems to attach to the frame with some pretty good support, but don't want to pull off the bumper.  This is probably only a one time move and the investment of a cass 3 hitch seems a little out of my range for one move.  I have looked through the manual for a weight restriction on the bumper but didn't find anything(although on the bumper it states look in the manual for restrictions).  I have a set of air bags already installed, which should help...is this doable or do I need a larger tow hitch.  O ya, what a great forum!!  Thanks
Back to Top View zeeker13's Profile Search for other posts by zeeker13
nissantech
Posted: Apr 13 2008 at 4:34pm | IP Logged Quote nissantech
I have seen several times the tongue weight limit stamped into the bumper around where the ball mounts.As far as the trailer weight you should be fine.Just try and determine your tongue weight.I think  200 lbs should be ok.
NissanTech
08 Black Nismo CC
Ipod dock
Sunroof
XM
Back to Top View nissantech's Profile Search for other posts by nissantech
zeeker13
Posted: Apr 13 2008 at 5:16pm | IP Logged Quote zeeker13
Hey thanks for the reply!  The tounge weight allowed is max 300lbs...I found that in the manual it wasn't stamped on the bumper.  I will try and find out the tounge weight of trailer... wouldn't you think that since the trailer weight is~ 1/2 of the max load for the truck(3001lbs), that the trailer would have less then the max tounge weight also(300lbs) all things proportional???  Anyway thanks for the reply, I would hate to see the bumper fall off after loading it.  If I had a reason for towing all the time, I would of course buy another hitch, but this is a one time thing...just dont want to turn it into a one time nightmare.  Also any ideas for the best wiring harness to go with this truck...is there a plug and play one available through a auto store or something?Thanks
nissantech
Posted: Apr 14 2008 at 9:05am | IP Logged Quote nissantech
I believe the major auto parts stores should have a plug and play wiring kit.I put on on a Dodge I had once  and it was a very simple install.
 Tongue weight is affected by how the load is placed.To far in front of the axle and you could have a issue.Now if the trailer is empty (you didn't mention what you were hauling) you're fine.
  Hope this helps.
NissanTech
08 Black Nismo CC
Ipod dock
Sunroof
XM
Chris6744
Posted: May 30 2008 at 11:17am | IP Logged Quote Chris6744
you should be ok
2007 nismo 4x4 cc (red)
3IN LIFT,TOYO MT'S,
Boise ,ID
dannyg
Posted: May 30 2008 at 10:58pm | IP Logged Quote dannyg
Get back safe and tell about the 2.4 pulling. A friend of minei s looking for somthing cheap on gas but still pull a 15 -17 foot bowrider
06 frontier 4.0 auto
