Frontier Towing / Hauling
Subject Topic: What is the heaviest thing you have towed Post ReplyPost New Topic
2006_FrontierLE
Posted: Mar 20 2007 at 8:18am | IP Logged Quote 2006_FrontierLE
I know that Nissan claims a 6500lbs. towing capacity (depending on model) but what is the heaviest load you guys have towed?
Short version of the story.  I am taking the entire month of May off to travel across the US and will be towing a 5000lbs (GVW), 25ft travel trailer.  I have no concerns on flat ground but when I hit the Rockies I don't want to overload my new (only 8k miles on it) 2006 Frontier LE.  And I don't want the truck maxing RPMs and going 10 mph up an incline.  I want it to feel like there is "almost" nothing back there.  I am starting to think I should have bought a Titan.
I am shopping for the travel trailer now and have been looking at units that are less than 4000lbs but found one I really like that weights 5000lbs.....
Thoughts?
Thanks,
  Brandon
  Midland, NC
Back to Top View 2006_FrontierLE's Profile Search for other posts by 2006_FrontierLE
Posted: Mar 20 2007 at 12:08pm | IP Logged Quote lakota
2006_FrontierLE;
One of the most beautiful places in the country is from the Front Range of Colorado westward to Four Corners and up to Moab.
Several of the Passes are over 10,000 feet up!
When you get there think about heat even though it’s cooler in the mountains. The manifolds will be glowing from hours of climbing just getting up to the steep grades.
... Dump all unneeded weight! Add a little extra air to the tires. If the vehicle is an automatic install a temperature gauge and an HD pre cooler mounted under the bed away from the exhaust. This will reduce heat in the radiator.
... All the gear boxes will also get hot and they do not cool off when stopped as quickly as you might think. When going down hill reduce gear to maximize engine braking and remember the engine may run cooler down hill but the transmission and gears are still getting hot. Watch closely for smoke from over heated brakes. Save the brakes and treat them like your life depended on them.
... I have been in climbing situations where the ambient wind flow and direction was close to the speed and direction of my travel and I was driving surrounded in the extra heat my truck was creating. This can happen on the highway or off-roading.
And the number one thing… Don’t be west bound on I-70 west of Denver in Friday afternoon rush hour traffic!
If something I’ve posted on the Internet offends you please ignore it. If you don’t know how to ignore something on the Internet e-mail me … and I’ll demonstrate.
ColinThePilot
Posted: Mar 31 2007 at 8:58pm | IP Logged Quote ColinThePilot
I tow a my sailboat regularly. the whole rig weighs 4500lbs. I also live at sea level in FL. I have a 6-spd so transmission temp isn't as much of a concern. something I noticed in the book is that Nissan recommends trailer brakes on anything over 1000lbs. I do fine with the brakeless boat rig, but again thats on flat ground at sea level. I'm thinking about putting a reactive brake system (dunno if thats the correct name for it) on the trailer. I've seen this on other trailers. The tongue has a hydraulic piston on it and when you brake, the weight of the trailer hits this piston and applies the right amound of braking for the trailer without a brake controller.
As far as "almost not feeling the trailer," good luck. I notice the trailer...a lot. The truck doesn't complain but its workin to pull that boat.
Hope I've been helpful. Enjoy your trip!
Back to Top View ColinThePilot's Profile Search for other posts by ColinThePilot
formula
Posted: Apr 12 2007 at 9:49pm | IP Logged Quote formula
I have an 06' CC 4WD.  I Just towed my 79' Firebird Formula on my 16' tandem trailer.  I was really impressed with how it handled it.  The trailer does have brakes which help tremendously.  I also invested in a Weight distributing hitch and it made all the difference in the world.  I sometimes tow a JD 4120 tractor which I figured weighs about as much as my car.  Towing with the WDH really made it feel alot safer.  My truck did not squat and it steered alot better.  It also tracked alot better.  Just something to think about.
Back to Top View formula's Profile Search for other posts by formula
2006_FrontierLE
Posted: Nov 09 2007 at 7:58pm | IP Logged Quote 2006_FrontierLE
Just a quick update....
I towed a 5000lbs trailer over 9000 miles in May on my cross country trek.  From steep mountains to flat plains....  114 degrees in death valley to 17 degrees in Yellowstone.
IT WAS A BLAST and the truck did GREAT!!!!
Death Valley
alex973
U.S. - New Jersey
Posted: Nov 30 2007 at 9:11pm | IP Logged Quote alex973
Howdee I tow my car easy for my NISMO 6 speed, going up to big POCONO my Nismo does well, however it squats. trailer and my car weight=4000LBS. towed to VIR for the season end race, basically flat going got 17.5 MPG which is good.
Question what can i do about the squat in the rear when towing
thanks
alex06NISMO
Back to Top View alex973's Profile Search for other posts by alex973
alex973
U.S. - New Jersey
Posted: Dec 07 2007 at 6:22pm | IP Logged Quote alex973
any body?
alex06NISMO
hsckris
U.S. - North Carolina
Posted: Dec 08 2007 at 8:44am | IP Logged Quote hsckris
alex973,
get firestone air springs. they are around 200$ i think.
it'll also keep it from squatting when you put stuff in the bed.
you just have to adjust the air pressure depending on whether you are
towing or just driving or hauling or what.
here is a link: http://store.summitracing.com/partdetail.asp?
autofilter=1∂=FIP%2D2403&N=700+4294746560+4294907666+4 2
94907042+4294806411+115&autoview=sku
In case that doesn't work: "Firestone Ride-Rite air helper springs are
heavy-duty, convoluted air springs that mount between the suspension
and frame of your vehicle. They can improve ride and handling, increase
traction, and reduce suspension fatigue. Ride-Rites are equipped with
individual inflation valves, so you can level your vehicle front-to-rear or
side-to-side when you're carrying off-center loads. They can boost your
load-carrying capacity from 3,200 to 5,000 lbs. per set. Some drilling
may be required."
06 Nissan Frontier KC SE 4x4.
03 Ford Focus ZX3.
Frontier Man
Posted: Dec 30 2007 at 9:54am | IP Logged Quote Frontier Man
Just moved from Ohio To Florida (1150 mi) pulling a 12 foot moving trailer. The trailer was packed from floor to roof-nose to tail as was the bed of the truck and I had no problems at all. I could definetly tell I was pulling the trailer but the truck provided all the power I needed. Very Impressed with the power the 4.0 V6 gives me.   LATER
06 Frontier SE 4x2 KC
Back to Top View Frontier Man's Profile Search for other posts by Frontier Man
djruss84
Posted: Jan 08 2008 at 7:26pm | IP Logged Quote djruss84
I have towed a 26' Box truck. I had to pull it out because someone left the lights on and it had to be jumped. By the way it was fully loaded too. Im not sure what weight it was but my truck pulled it no problem. I just took it slow.
Proud Owner of a:
06 Frontier SE 4x4
Back to Top View djruss84's Profile Search for other posts by djruss84
Page of 2 Next >>
