Frontier Towing / Hauling
Subject Topic: Overload Springs Post ReplyPost New Topic
JFordBronco
U.S. - Louisiana
Posted: Jan 10 2007 at 1:09pm | IP Logged Quote JFordBronco
Has anyone here used the Superspring Overload springs?  I will be going to TX in about two months and will be putting my Yamaha Big Bear 400 in the back of my truck.  The bad thing is, with it in there as it is, it squats the truck badly.
Joel
2005 Nissan Frontier Nismo - tow rig. 1995 Ford Bronco XL with 6" lift and soon to be 35's and 2007 Yamaha Big Bear both are my play toys.
Back to Top View JFordBronco's Profile Search for other posts by JFordBronco
fishmonger
U.S. - Colorado
Posted: Jan 16 2007 at 12:41am | IP Logged Quote fishmonger
I have an earlier 2001 2wd Frontier with a lot of stuff in my truck.  I had used Helwig overload springs before but on this truck I tiried Firestone Ride-Rite Air bags.  I carry a minimum of 1000 lbs in my truck bed all the time.  The air bags seem to work well.  I have not seen the brackets for the newer Fronty but here is what I found on this one.  The clearance between airbag and tire is close enough that I will not be able to use chains.  The instruction sheet was written by a dyslexic moron.  Use your common sense and the install was pretty easy.  No metal drilling or special tools (had to drill plastic bumper though).  To protect the air lines, I route them through 5/16 gasoline line.  You will need to buy some extra nylon ties.   The gas line keeps the hard plastic lines from rubbing on steel, gives them some protection from flying gravel or ice chunks, I do not use a compressor, just route them so they exit at the license plate holes in the bumper.  I did need to drill the plastic bumper holes a little bigger to put the schraeder valves through the bumper.  With a 1200-1500 lbs load, I keep the bags at 40-50 PSI.   I have heard that if you do off road the truck, use Higher grade bolts to mount the brackets and air bag.  I have had no problems but one of the guys I work with drives off road and had to go to high grade bolts.
Advantages of air bags;  you can adjust the air to fit the load.  The empty bed still requires 10 lbs to keep the bags from damage when empty.   You do not get the hard as a rock rear spring a steel overload will give you.  This increases brake distances, gives a rough ride and I found it very difficult to drive in wet or snow when I tried the steel over loads alone in an empty truck.
My current truck  is my 4th Nissan  in 14 years.  I have put as much as 1800 lbs in the air bag equiped truck.   I did put more weight in truck # 2 but it had the Helwigs and Timbrens, That one was a 94 2wd D 21 or hardbody.  the third truck was a 97 with just the helwigs,  I had all the rough ride, lack of traction empty, increased brake distance problems when the truck was empty.
One final note, I use Bilstein shocks, They have lasted as much as 240,000 miles.  They really do a great job with heavy loads and last forever.  I wore out some other brands in as little as 5,000 miles and they made me sea sick.
Back to Top View fishmonger's Profile Search for other posts by fishmonger
JFordBronco
U.S. - Louisiana
Posted: Jan 16 2007 at 6:44am | IP Logged Quote JFordBronco
Well, my Super Spring overload springs are supposed to come in today.  I searched Hellwig and they didn't have them yet, they are in research still.  I'll post up when I have them on and let you know the ease of install or lack of ease of install.
Joel
JFordBronco
U.S. - Louisiana
Posted: Jan 16 2007 at 10:28am | IP Logged Quote JFordBronco
Well, they came first thing this morning, I put them on in about an hour...taking my time and making sure I didn't miss anything.  Did you notice your truck lifted a little bit in the back?  It seems about an inch higher and rides a little harsher.  Part of that, I believe though is due to a blown shock.  While I was under it, I saw oily crap all over the driver rear shock, I am assuming that is what it was.  Overall, they seem ok, I just need to find a front leveling kit now.
Joel
formula
Posted: Jan 23 2007 at 8:41pm | IP Logged Quote formula
So how do you like your Supersprings?  I have been kicking around the idea of getting a set for a few months now.  Then I started reading about air bags.  The springs seem like they would be easier, less maintenance and cheaper.  How is the ride?  Did you get the SSA2 or SSA7?
Back to Top View formula's Profile Search for other posts by formula
JFordBronco
U.S. - Louisiana
Posted: Jan 24 2007 at 4:30am | IP Logged Quote JFordBronco
Funny you asked, I took them off.  I actually got i touch with the co-owner - atleast he said he was and it took me forever.  I kept bottoming out with them things.  I took my digital camera and took some pics of everything, called and waited and waited and waited to get in touch with him and sent him some pics.  Anyway, depending on what year yours is, you may have two "bumptstops."  I have two, you have to trim one and leave the other untouched.   I kept bottoming out on the one that is on the bottom of the frame rail.  After almost an hour, he said he will send me some SSA7 in the mail for free to try for a week and then call him back and let him know if they are better or worse.  Originally I had the A2's and he said that they may be just too small/weak for my truck.  I only load a 4-wheeler in the back of it.  As soon as this happens, I will post up....so stand by.
Joel
fishmonger
U.S. - Colorado
Posted: Jan 24 2007 at 10:39am | IP Logged Quote fishmonger
This is why I like the air bag idea.  I was the last one of the 8 guys I work with to  go to airbags.  This week I needed to use the truck with almost no load in a snowstorm so I was able to reduce the air pressure and still have traction.  When I just used overload springs  (Helwigs) , rain or slick conditions were a nightmare because of loss of traction both going and stopping.  If you are not going serious 4 wheeling off road, and lets face it most truck owners do not, the air bags are a much better way to increase load capacity, In my humble opinion of course.
JFordBronco
U.S. - Louisiana
Posted: Jan 24 2007 at 10:45am | IP Logged Quote JFordBronco
The only thing I use mine for is taking my 4-wheeler on trips and towing my Bronco.  I wouldn't even put "helper anythings" in if my 4-wheeler wouldn't bottom me out.
Joel
formula
Posted: Jan 24 2007 at 4:10pm | IP Logged Quote formula
Well let me know what happens with the SSA7's.  I called and asked them about the bumpstops and they told me that I didn't need them because I would never bottom out the supersprings, guess they were wrong.  Hey Fishmonger, what kind of air bags do you have?  Where did you get them.  I am like JFordBronco, I put my Brute Force 750 in the back of my truck and pull my 16ft trailer with 2 more 4-wheelers behind it.  I just want something to keep it more level and stable.
fishmonger
U.S. - Colorado
Posted: Jan 24 2007 at 6:24pm | IP Logged Quote fishmonger
I bought the air bags and the bilstein shocks  from truckspring.com Good prices and fast shipping.  Buy extra nylon ties, I used big ones for going around the frame and smaller ones to attatch the air lines to the larger nylon ties.  The air lines do not move that way and if you do have to repair, the small ties are very cheap.  The trick with the gasoline line was recomended by an off road friend, gravel and ice chunks can damage the air lines in extreme cold weather.  I travel a lot of miles so I bought a spair airline kit with extra fittings just to have on hand.  I have not used it but I cannot afford a week with out work because I did not have a $31.42 airline kit.  Between myself and the guys I work with, we have put 500,000 miles on air bag equiped trucks in the last 5 years.
Page of 3 Next >>
