New England/Mid Atlantic
 Nissan Frontier Forums : New England/Mid Atlantic
Subject Topic: Timing Advance Post ReplyPost New Topic
silverkorn
Posted: Oct 17 2008 at 7:28pm | IP Logged Quote silverkorn
hey guys just joined the forums, i am a Titan owner who has been performing timing advances on all kinds of Nissan's in the NY/NJ area and wanted to pass on my info for you guys as well.
send me either a private message or email if your looking to have this done.
TSR Motorsports - AMSOIL Dealer
Back to Top View silverkorn's Profile Search for other posts by silverkorn Visit silverkorn's Homepage
Posted: Oct 17 2008 at 8:10pm | IP Logged Quote frontierguy
What are the reports on mileage -increase/decrease???? I'm running 91 sunoco in my 08 Frontier (lots of power) but any help in mileage is a plus. I've used that function on the Consult 2, but never experimented on my own vehicle. Thanks for the info. Also using Amsoil 5w-30 100% synthetic for the first time.
silverkorn
Posted: Nov 04 2008 at 5:27pm | IP Logged Quote silverkorn
i have seen some reports on people getting better gas mileage and some people saying they are getting worse. its hard to tell cause people said they were also on the throttle more now that the truck seems to drive much better now.
i have had the timing advance on my titan for over a a year and half and never had any problems. i still to this day run the regular 87 octane gas and it has held the timing advance the entire time. if your running 91 octance right now then your really missing out on the timing advance.
the biggest advantage of getting the timing advance done is the throttle response is much better then stock. its hard to describe but once you drive the truck after having it done it feels much quicker on the gas. if you have access to the Consult 3, which is required to do for 2008 or newer models right now, then you have nothing to loose to try it on your frontier.
also if your not getting a deal on the AMSOIL send me an email and i'll set you up with a better price.
Posted: Nov 04 2008 at 8:50pm | IP Logged Quote frontierguy
Silvercorn, thanks for the reply,I'll give it a try.
Paid $8.25 qt for the 100% synthetic 5w-30
silverkorn
Posted: Nov 07 2008 at 4:12pm | IP Logged Quote silverkorn
send me an email (woodruffk@tsrmotorsports.com) and i'll pay for your preferred customer 6 month membership which will get you AMSOIL 5W-30 100% synthetic (ASL) for $6.95 a quart, before shipping and taxes.
and let me know how you liked the timing advance, as im sure you will
bhowe
U.S. - New York
Posted: Nov 22 2008 at 10:40pm | IP Logged Quote bhowe
Nobody ever gained anything by running too far advanced or too lean.
That has been common knowledge for years.
Too hot, burnt valves, etc.
Chips that re curve timing and fuel delivery are another story.
You can get added performance or economy depending on how you drive.
Back to Top View bhowe's Profile Search for other posts by bhowe
silverkorn
Posted: Nov 28 2008 at 3:36pm | IP Logged Quote silverkorn
by increasing the timing only 2 degress your not going too far advanced to not see any advantages. You can benefit by increasing your timing beyond 2 degrees but you would be required to runner a higher octane fuel in order to prevent detination. only going 2 degrees your not required to run higher octane fuel then the standard 87 octane as directed by Nissan.
