leesecrew Newbie
Posted: Mar 18 2005 at 7:45pm | IP Logged
Does anybody know the trick to getting the dash apart where the radio mounts so I can upgrade it? IT looks like it just has pop in clips, but I dont want just start ripping stuff apart.
Frontier Admin Group
Nissan Frontier Forums Master Admin
Online Status: Offline Posts: 99
Posted: Mar 19 2005 at 1:43pm | IP Logged
What year is your Frontier?
__________________ Chicks Dig NISSANS
http://www.nissanfrontier.org
Purchase a NissanFrontier.org Sticker
Vebro Solutions Advertisement Network
leesecrew Newbie
Posted: Mar 21 2005 at 6:33am | IP Logged
It is a 02 crew cab with single CD player.
shawn Newbie
Posted: Mar 23 2005 at 2:02am | IP Logged
i had mine done for me i have a 2000
__________________ nissan rules
leesecrew Newbie
Posted: Mar 29 2005 at 8:53pm | IP Logged
Just for everyones info.... I just replaced my factory radio with a Pioneer unit. To get the dash apart : take the cover off the shifter and console off first. It has several "pop in" clips. You will have to pull the shifter in drive to get the cover off. There are four screws holding the radio/ a/c panel in. Two at the bottom (where you removed the console cover) and two under the a/c controls. After you remove those, the radio / a/c panel pops off. Remove the harnesses for the 12V supply port and emergency flasher switch. Then remove the four screws from the radio mount, plugs, and antenna wire to remove the radio. I used a BEST harness kit (BHA7550)and BEST universal pocket (BKUPK750). Both with tax set me back $37. I followed the directions on both and had no problems. Make sure that you connect the ground wire to a screw on the body. I found one right on the LH side floor in front of the heater box. The wiring kit although it has a ground wire, the factory plug doesn't where it connects. Good Luck! The web site for BEST is www.bestkits.com
__________________ Newbie....how cruel!!!
blackmagicx Moderator Group
Posted: Apr 05 2005 at 5:45pm | IP Logged
you know what i didn't have to take my console apart, 2001 6disc, but i can't remember how the whole process went.
myles Moderator Group
Posted: Apr 06 2005 at 3:50pm | IP Logged
ive got a pioneer cd player on the way and soon ill be doin that same thing. This website below i use a lot to figure out how to get this sh*t apart, for any type of car. I mean like when i install it in my friends car because you know they figure "well you're an electrician, install my stereo" hah, electronics is different than electrical work, IE black is hot in electrical work and it's ground in electronics. Just a little knowledge for ya, haha.
http://www.carstereoremoval.com/htm/stereoremovalNissanFront ier00_02P.htm
__________________ - Myles -
2000 Nissan Frontier (extended cab)
1 JL Audio 10" Powerwedge hooked up to a JL Audio 500/1 (oh yeah :D)
Posted: Apr 06 2005 at 3:54pm | IP Logged
Nevermind about that website, they are CHARGING you now! Ugh! Everybody wants to make money, they never used to charge, oh well. Been locked up for a year so i guess some things will change..
Joehova Senior Member
Posted: Apr 08 2005 at 9:36am | IP Logged
Isn't that the truth. I was doing the same thing recently.. all I wanted to know was the factory wiring harness for a chevy silverado and some website wanted like $15 to tell me blue is power and blah blah blah... It's the same on ebay... it's all business and you don't really save a whole lot. You have to search for the deals.
