Mobile Audio / Electronics
Subject Topic: Subwoofer placing 2001 XE shortbed. Post ReplyPost New Topic
Mr. Merritt
Posted: Aug 10 2005 at 10:35pm | IP Logged Quote Mr. Merritt
I've found that I would be able to put two 12 inch subwoofers facing the back of the cab if placed low on the wall. The woofers would have enough foom as long as the seat isn't slid back all the way.
My question is:
How would one go about attaching the woofers to the back of the truck, since I'm pretty sure there are only two layers of sheetmetal.
2001 Frontier Shortbed XE
Four Cylinder Manual
Back to Top View Mr. Merritt's Profile Search for other posts by Mr. Merritt
Joehova
U.S. - Colorado
Posted: Aug 11 2005 at 12:47pm | IP Logged Quote Joehova
Rather than using screws that would penetrate through the sheet metal... maybe you could take a couple of nuts and spot weld them on the metal... that way you could use a short bolt and connect the box... Just an idea though...
---Joe---
05 NISMO 4x4
Back to Top View Joehova's Profile Search for other posts by Joehova
Mr. Merritt
Posted: Aug 11 2005 at 3:49pm | IP Logged Quote Mr. Merritt
wow. i didnt even think of that.
im going to attempt that. thank you for that idea. im amazed.
thanks.
note: none of this is sarcastic.
Posted: Aug 11 2005 at 6:23pm | IP Logged Quote kcidmil
Just get a fiberglass cover and fill the bed with subs
