badpatten Groupie
Posted: Aug 01 2005 at 9:08am | IP Logged
Ok, I have been to three different car stereo stores and searched on Crutchfield for the exact sizes for speaker replacement. Is it 6x9's in the front and 6.5's in the back or 6.5's all around? I don't want to take the door covers off to look.
Thanks, Brian
__________________ 2005 SE KC Storm Gray/Graphite
2005 Nissan Xterra SE 4x4 Night Armor
2006 Scion TC
1972 Datsun 620 pickup
msubullyfan Newbie
Posted: Aug 02 2005 at 6:27pm | IP Logged
6x9 in the front, 6.5 in the rear.
Be careful with the front -- the speakers are installed in plastic spacer tubes that are attached to the door frame. You absolutely CANNOT put in speakers that are deeper than this spacer tube. Crutchfield lists max mounting depth at 3.014". I installed Alpine 3-ways that were 3.125", and they fit, but anything much deeper won't work.
chriscscs Newbie
Posted: Aug 02 2005 at 9:34pm | IP Logged
Is it possible to put 6.5" in the front? I got the POlk components from Crutchfield and they listed 6.5" as the front fit. I would imagine the adapter kit will allow this?
Posted: Aug 02 2005 at 10:35pm | IP Logged
I think it all depends upon which year and package your frontier is.
chriscscs Newbie
Posted: Aug 03 2005 at 12:30am | IP Logged
kcidmil wrote:
I think it all depends upon which year and package your frontier is. |
Sorry, 05 crew cab se, no fosgate
badpatten Groupie
Posted: Aug 03 2005 at 10:59am | IP Logged
Thanks, I picked up some Polk 6.5's for the rear from a coworker for $50 so now I just have to get the 6x9's Did you install them yourself? I hate taking off the door panels, in fear of them not going back on right.
2006 Scion TC
Strs90 Newbie
Posted: Aug 14 2005 at 10:45pm | IP Logged
Delete
wyomingbob Newbie
Posted: Sep 25 2005 at 2:41pm | IP Logged
This is a very late reply but perhaps worthwhile for someone in the
future. Two things to consider, both learned from trial and
error:
First, the speaker depth clearance may be OK with the
windows UP, but can become insufficient when you wind them
down. A lowered window in Frontier can slap the spkr magnet
(you'll hear it), and with enough door slamming may shatter inside the
door. My 04 required a 1/2" spacer with Alpines that were
*supposed* to be shallow enough.
Second, anytime you start using spacers, the
electrical connections on the speakers might
come in contact with the door metal. So tape (insulate) the
section of
speaker cutout in the door closest to the connectors. Also wrap
the
connectors with several small pieces of tape. Scotch Super 33 is
a good electrical tape. NOTE: The Frontier stock radio
apparently has overload protection and will shut down the audio amp if
there is a speaker short. Fix the short and it will work again.
Or don't fix it and tell your wife you need a new Kenwood.
__________________ ~~~~~~~~~~~~~~~~~
2004 SC 4x4 Crew
Posted: Sep 25 2005 at 6:12pm | IP Logged
For those of you what are having problems with this... and don't feel like dealing with it. Check out these.
www.illusionaudio.com
wyomingbob Newbie
Posted: Sep 26 2005 at 1:28am | IP Logged
Looking through Crutchfield, I see that you can put a 6x9 in front and
a 6.5/6.75 in back. I used the "What fits my vehicle?" option on
their site, plugging in a 2005 KC with 4 speakers, assuming you don't
have the 6-speaker configuration. You can also use 6-3/4 or
smaller sizes all around, with Crutchfield's supplied adaptors.
They recommend only ONE 6x9 that will fit: the Alpine Type-R SPR-69LP, 2-way Speaker ($160). The others that fit the front are, from cheapest to most expensive:
Kenwood KFC-1669S, 6-1/2" 2-way Speakers
Pioneer TS-G1340R, 5-1/4" 2-way Speakers
Kicker 05KS525, 5-1/4" 2-Way Speakers
Kicker 05KS60, 6-1/2" 2-Way Speakers
Boston Acoustics S65RC, 6-1/2" 2-way Speakers Shallow Mount
Infinity Kappa 50.7cs, 5-1/4" Component System
Boston Acoustics Pro50, 5-1/4" Component System
The available rear speakers, from cheapest to most expensive, are:
Blaupunkt PCxb542, 5-1/4" 2-way Speakers
Blaupunkt PCxb652, 6-1/2" 2-way Speakers
JVC CS-V624, 6-1/2" 2-Way Speakers
Pioneer TS-G1640R, 6-1/2" 2-way Speakers
Kicker 05DS525, 5-1/4" 2-way Speakers
Sony XS-V1330A, 5-1/4" 3-way Speakers
Rockford Fosgate P152C, 5-1/4" 2-way Speakers
Kenwood KFC-1379ie, 5-1/4" 2-way Speakers
Kenwood KFC-1679ie, 6-1/2" 2-way Speakers
Kicker 05DS60, 6-1/2" 2-way Speakers
Audiobahn 2050N, 5-1/4" 2-way Speakers
Pioneer TS-A1370R, 5-1/4" 3-way Speakers
Pioneer TS-A1671R, 6-1/2"/6-3/4" 3-Way Speakers
Rockford Fosgate P162C, 6-1/2" 2-way Speakers (shallow mount)
Alpine SPS-130A, 5-1/4" 2-way Speakers
Kenwood KFC-1389ie, 5-1/4" 3-way Speakers
Polk Audio db 525, 5-1/4" 2-way Speakers
Sony XS-V1335X, 5-1/4" 3-way Speakers
Alpine SPS-170A, 6-1/2"/6-3/4" 2-way Speakers
Boston Acoustics S55, 5-1/4" 2-way Speakers
Infinity Reference 5012i, 5-1/4" 2-way Speakers
Infinity Reference 6012i, 6-1/2" 2-way Speakers
Infinity Reference 6012si, 6-1/2" Shallow 2-way Speakers
Pioneer TS-A1681R, 6-1/2"/6-3/4" 4-Way Speakers
Polk Audio db 650, 6-1/2" 2-way Speakers
Sony XS-V1635X, 6-1/2" 3-way speakers
Sony XS-V1641H, 6-1/2" 4-way Speakers
Sony XS-S160CX, 6-1/2" 2-way speakers
Infinity Kappa 52.7i, 5-1/4" 2-way Speakers
Infinity Kappa 62.7i, 6-1/2" 2-way Speakers
Polk Momo MMC 525, 5-1/4" 2-way Speakers
Pioneer TS-D161R, 6-1/2" 2-way Speakers
Polk Momo MMC 650, 6-1/2" 2-way Speakers
If you like the sound of the 6x9, you might stick with it and go the
Alpine route, front and rear. Some prefer round speakers over
ovals, and would tend to choose the Kickers, Boston or component
systems - again keeping the same brands front and rear. Unless you
actually need size adapters, connectors, etc. and can ONLY find them at
Crutchfield, you can shop elsewhere on the Net and possibly save about
25%. Hope this helps.
2004 SC 4x4 Crew
