Posted: Aug 03 2007 at 12:37pm | IP Logged
Hi Everyone,
I installed a new Alpine head unit in my '04 Frontier. I had the stock Rockford Fosgate system and I bypassed the stock amp with the new head unit. Everything works great but I get a fluttering sound from a relay near the fusebox when I am in the Accessory position on the key. It is the same sound that you get when you don't have good battery contact but I double checked the connections and they are tight. Any other thoughts? I pulled the fuse for the amp under the hood, since this is not needed now. I have not driven the truck yet so see if it happens then but I wanted to know if anyone has had this happen. Thanks.
