Subject Topic: cold air intake? Post ReplyPost New Topic
valentin_84
U.S. - Arizona
Posted: Aug 01 2006 at 1:51am | IP Logged Quote valentin_84
hey guys i have a o1 frontier 2.4L and i want to give it a bit more power. i can only find cold air intakes for the v6! who makes one for the 4 and is there anything that i can also do that is pretty cheap to get a lil more power?
valentin
Back to Top View valentin_84's Profile Search for other posts by valentin_84
Posted: Aug 01 2006 at 7:39am | IP Logged Quote kcidmil
www.4x4parts.com  there are plenty of intakes out there, you just have to search a little harder.
Also, try reading this thread.  It's a sticky in the Performance and Modification section, called "The Basics of Adding HP"  Some very good info in there.
http://www.nissanfrontier.org/forum_posts.asp?TID=124&PN =1
valentin_84
U.S. - Arizona
Posted: Aug 02 2006 at 6:11pm | IP Logged Quote valentin_84
hey i tried that site and still only cold air intakes for v6's. nothin for the 2.4L engine i have. ive looked at probably 20 sites and still nothing. anyone know where i can get one?
valentin
Posted: Aug 02 2006 at 9:47pm | IP Logged Quote kcidmil
Try looking again under "Performer Intakes"
http://www.4x4parts.com/public_html/shop/index.php3?page=sho p/browse&category_id=1a2b1d7f7afee6259fdd73ea764358b3&am p;ps_session=8575ca447dc6d9c9f87b728693a755b9
davidweed
U.S. - Washington
Posted: Aug 07 2006 at 1:36pm | IP Logged Quote davidweed
Are there any dissadvantages to installing a CAI (other than fronting the $300 or so bucks)?  Does it do anything to the life of the engine or any other such mechanical downsides?
David
2006 NISMO 4x4 Crew Cab
Rockford-Fosgate Package
Traction Package
Sunroof and roof rack
Towing package
Back to Top View davidweed's Profile Search for other posts by davidweed
jptabor24
Posted: Aug 07 2006 at 3:34pm | IP Logged Quote jptabor24
i am not too sure of any disadvantages in installing a CAI, but there are plenty advantages that i am sure outweigh the cons.  Valentin_84 try emailing this guy and tell him JP Tabor sent you.  azoffroad@qwest.net ask him for your application and he can get you a quote, i got an Airaid intake for less than $200.  It has done very well for me.
JP Tabor
2001 Frontier CC
Back to Top View jptabor24's Profile Search for other posts by jptabor24 Visit jptabor24's Homepage
ColinThePilot
Posted: Aug 07 2006 at 3:39pm | IP Logged Quote ColinThePilot
My 06 4.0 V6 appears to have a cold air already. The airbox is next to the driver side wheel well and another tube goes through the wheel well from the airbox. That sounds like cold air to me, right? Or am I totally out there?
Back to Top View ColinThePilot's Profile Search for other posts by ColinThePilot
Posted: Aug 07 2006 at 5:11pm | IP Logged Quote kcidmil
Picture would help
Mylt1
U.S. - Virginia
Posted: Aug 08 2006 at 10:27am | IP Logged Quote Mylt1
thats just the standard intake. the only way to actualy have a true "cold air intake" you to remove the TB heater and have a clean source of outside air. there is a guy on clubtitan that has turned his TB heater into a TB cooler. he is running a trans cooler with a pump that mounts in front of the rad. then plumbed the lines into the TB. so he is cooling the TB instead of heating it. the only problem i see with this is the ecm may keep the truck in "warm up" mode longer than normal.
People
Eating
Tasty
Animals
Back to Top View Mylt1's Profile Search for other posts by Mylt1
ColinThePilot
Posted: Aug 08 2006 at 12:44pm | IP Logged Quote ColinThePilot
This sort of in depth engine mod stuff is still above my level, so forgive me for newbie questions. Why is the TB heated in the first place? That would make the mixture rich, thus burn more gas, right? Second, is that a kit or did the Titan guy just make it up himself? And does cooling the TB really make much of a power/efficiency difference?
Can you link that thread on clubtitan?
Page of 2 Next >>
