Posted: Jul 03 2006 at 12:27pm | IP Logged
Well the 01 is the older body style with square headlights, 02 had the composite.
Not much is difference between the 2 years besides styles. Engines and drivetrains are the same. Except that in 02 they offered a Supercharged edition. In MY all honesty, it's worthless, and can increase your insurance for nothing. If you decide to get it, think about upgrading it ASAP.
For the difference between XE and SE.... not much either. Usual interior choices, foglights, on some of the 02s XE had black fenderflares, SE had Color Matched.
You'll just have to kind of look around and try each one out. They last for awhile, and have very minor problems (02 2wd develop loose bolts on the front end, causing a popping noise) But it also depends upon how the previous owner treated it. I've ran into a S/C edition that was torn up. I've even run into the VERY RARE 01/02, 02 bodystyling, 01 interior.
