Subject Topic: egr valve removal Post ReplyPost New Topic
kylo
Posted: Jun 15 2011 at 5:26pm | IP Logged Quote kylo
I have a 2004 frontier with 4 cyl engine. On the valve is a big tube that comes in from the rear of the engine. I cannot get the flare nut loose.It looks to be about
1 -1/8". There's no room to get a turn with the wrench.I can get an open end on it but the side is against the intake manifold.Also it has been on for 185,000 miles.Any help would be appreciated.Am I able to remove the tube from the other end and take it off with the valve and work on it once its out?
Back to Top View kylo's Profile Search for other posts by kylo
Posted: Jun 15 2011 at 8:10pm | IP Logged Quote frontierguy
You may need a different wrench that is off-set to achieve
the correct swing. Did you remove the BPT valve for more accessibility?
kylo
Posted: Jun 15 2011 at 8:37pm | IP Logged Quote kylo
Yes the BPT was removed. I ordered a crowsfoot wrench tonight. It should give me the swing I need.
