Subject Topic: Squeek Post ReplyPost New Topic
Just-n
Posted: May 29 2011 at 12:41am | IP Logged Quote Just-n
I have a 2007 Nissan Frontier Crew Cab bought it new.I've heard this squeek for a while now and can't pin point where it's coming from.When I go over a bump,shut the door or even stand on the bumper and jump up and down it will squeek.Not sure if it's under the hood or under the dash.It's driving me crazy.It also started to whine thought it was the power steering pump but read the forum and found out it's probably the tsb going to have it checked out.Any suggestions on where to check would help thank you.
Back to Top View Just-n's Profile Search for other posts by Just-n
Posted: May 29 2011 at 8:31pm | IP Logged Quote frontierguy
Lube all 3 hood rubber stops. The whine is most likely the
secondary timing chain tensioner shoes.
