Posted: May 20 2011 at 4:15pm | IP Logged
If it is just the bed... spacers can be added to the lowest mounting points. I have not looked but many pick-ups have six bolts holding the bed to the frame. It could be the something in the suspension is weak or bent.. Perhaps a small spacer on one side between the rear axle and spring. A good automotive body man should be able to look at it and see what it needs. Drive it by the house here... I'll look at it!!!
Hope you get it fixed up.. Don S..
