Posted: Jan 31 2011 at 10:00pm | IP Logged
Don't have one right now,and the hole in the cowl behind hood is present.Found a couple in the junkyard on Exterras.But their cable "dissapears" up behind the heater/ducting under the glove box-rendering removing immpossible w/o removing majority of under/in dash stuff first.Thinking I'm going to be useing an aftermarket stereo,which take a generic type antenna cable connection,why could'nt I just cut the cable from an OEM base,and solder splice a generic cable allowing me to route it to the stereo and eliminating the need for an antenna adapter as well.
