Subject Topic: LIFT KITS Post ReplyPost New Topic
thepatriot
U.S. - New York
Posted: Dec 16 2010 at 2:20pm | IP Logged Quote thepatriot
I am the new owner of an 02 supercharged crew cab w/long bed. I am thinking of adding a lift kit but dont know which to go with a supsension lift or body...whats the difference between the two and which brand should I go with?
Thnaks Dominick
patriot@hvc.rr.com
Back to Top View thepatriot's Profile Search for other posts by thepatriot
fronty_78
Posted: Dec 16 2010 at 4:48pm | IP Logged Quote fronty_78
Hey Dominick,
Congrats on your new truck.  I Just bought an '05 myself.  As far as your question goes, I don't know which brands most frontier owners prefer, i do know this however.  A body lift typically uses the stock suspension components with the addition of polyurethane blocks and some small parts for the increased height.  Suspension lifts use longer travel, tougher compenents, replacing your stock ones. Suspension lifts are the way to go if you plan on heavy abuse, oh and if you've got the cash to fork out.  They ain't cheap brother.  If you're looking for a bit more ground clearance then i'd say go with the body lift.  I'm sure someone here can expand on this and give you a better idea or point you in a more clear direction but that should provide a basis.
Good luck!
Back to Top View fronty_78's Profile Search for other posts by fronty_78 Visit fronty_78's Homepage
thepatriot
U.S. - New York
Posted: Dec 17 2010 at 4:49pm | IP Logged Quote thepatriot
Hey, Thanks for taking the time to answer. I really dont do much off roading...looking really to get a little more ground clearance so a body lift may be the way to go. I had an 04 Dodge Hemi 1500 and recently got stuck in some mud...to my suprise I could not get out without digging around the tires that were spinning!! I found out quick that a limited slip diff does the oppiste that it should be doing in that situation...cant understand why they work that way...anway no Im looking into the Powertrax No Slip! Like Isaid...I dont off raod much but I also dont want to get stuck! Thanks...
http://www.rockcrawler.com/techreports/powertrax_tj/index.ht m
