Subject Topic: 2008 fog lights Post ReplyPost New Topic
hocman123
Posted: Nov 29 2009 at 8:17pm | IP Logged Quote hocman123
i just got my 08 frontier about a month ago now, and i love it, but i do want to put in some nice fog lights on it not sure the best way about going about it. i know they have the holes in the front bumper with a decoritive little plug in it. can i remove them and get lights meant to fit properly in the holes or do i need to mount them somewere else. also if i can use the holes in the bumper what is a good site that might have premade kits in installing and wiring the lights. Thanks ahead of time
Back to Top View hocman123's Profile Search for other posts by hocman123
BENT_TWIG85
Posted: Nov 30 2009 at 12:02pm | IP Logged Quote BENT_TWIG85
i bought aftermarket silverstar fog light and mounted them in the holes made for the fog lights and they are bright as hell. u may look into that and see what u think about it but i really like mine
WICKED INTENTIONS
Back to Top View BENT_TWIG85's Profile Search for other posts by BENT_TWIG85
davidjbrady
Posted: Dec 01 2009 at 8:27am | IP Logged Quote davidjbrady
Were you able to find the wires for the switch under the dash? I see the wires under the bumper, but did not find them under the dash. I am not sure where the OEM switch is located, is it below the radio or is it below the steering wheel on the left side. It would be a simple hook up if I could find it. I had thought about doing the same thing too.
08 Frontier CC, 4X4, LWB
hocman123
Posted: Dec 01 2009 at 4:40pm | IP Logged Quote hocman123
i did not even know the caps have wires going to it i looked but it was only a quick glance i will check again but if there is wires there could be a wire layout in the manual or u might have to buy a haynes repair manual they have wirelayouts in it
Posted: Dec 01 2009 at 8:35pm | IP Logged Quote frontierguy
All parts available through your Nissan dealer, the switch replaces the current t/s-headlite switch, wiring is there for the lites. Very simple,high quality lites.
Following parts needed to install fog lites:
1-25540-ET11A switch
1- 26150-EA825 lamp
1-26155-EA825 lamp
1-62256-EA800 bezel
1-62257-EA800 bezel
4-08146-6162G bolts
Wiring is already there, these will fit chrome bumper vehicles.
hocman123
Posted: Dec 01 2009 at 10:48pm | IP Logged Quote hocman123
hi thanks a lot this is what i was hopeing to hear
ezramore
Posted: Feb 05 2010 at 10:13am | IP Logged Quote ezramore
parts at dealer are rediculus in price. Bought mine here. http://www.amazon.com/2005-2009-Nissan-Frontier-Assembly-Chr ome/dp/B002PQOE7M you will still need to get the switch from the dealer and spend a few minutes picking up the bolts as the kit does not come with them. Takes about 5 miutes to inslall the whole thing. The plastic rings were 6$ at the dealer rather than modifying the stock plugs.
Back to Top View ezramore's Profile Search for other posts by ezramore
Posted: Feb 05 2010 at 5:58pm | IP Logged Quote frontierguy
You get what you pay for!!!
< id="gwProxy" ="">< ="jsCall();" id="jsProxy" ="">
ezramore
Posted: Feb 05 2010 at 6:37pm | IP Logged Quote ezramore
frontierguy wrote:
here. Assembly-Chrome/dp/B002PQOE7M"> http://www.amazon.com/2005-
 you
You
get what you pay for!!!< id="gwProxy" =""><!--Session -->< ="jsCall();"
id="jsProxy" =""><div id="ref">
I agree in most things. The ones I got use the same bulbs as the
dealer ones and are almost a quarter of the total cost of the Dealer
ones
