Subject Topic: flooded engine Post ReplyPost New Topic
r cone
Posted: Nov 19 2009 at 4:21am | IP Logged Quote r cone
I have a 2003 xe 4 cyl.   Ive heard all the horror stories about flooded engines, but....  after doing all the obvious stuff (clear cylinders, distrib, oil change, air, etc) the truck does run...rough but continous.  Is there a way to reset the computer or...  if replacing with a used one, will it work with the sytem in mine?  Also, Ive heard of oxigen sensors causing probs in other vehicles.  Does this truck have one?
Back to Top View r cone's Profile Search for other posts by r cone
Posted: Nov 19 2009 at 8:06pm | IP Logged Quote frontierguy
It sounds like you need a professional to get to the root of your problem.
davidjbrady
Posted: Dec 01 2009 at 8:40am | IP Logged Quote davidjbrady
Do you mean you have a truck that is idling rough?
Do you smell fuel?
What about a vacuum leak?
08 Frontier CC, 4X4, LWB
