Subject Topic: 98 frontier gauges don’t work Post ReplyPost New Topic
RBlanton
Posted: Nov 12 2009 at 10:53am | IP Logged Quote RBlanton
I have a 98 frontier that none of the gauges on the dash work. sometimes they work and then go back off. The speed odometer and temp gauge,gas gauge all gauges don't work. could anybody give a clue where to check? I've already checked the fuse under the dash.
Back to Top View RBlanton's Profile Search for other posts by RBlanton
Posted: Nov 12 2009 at 7:36pm | IP Logged Quote frontierguy
Remove the meter assembly, tighten all the screws on the printed circuit board. Tighten the grounds behind the left and right kick panels. If that doesn't help, most likely it will need a unified meter control unit( the whole meter assy.)
RBlanton
Posted: Nov 13 2009 at 6:28am | IP Logged Quote RBlanton
Where is the meter assembly located?
Posted: Nov 13 2009 at 4:40pm | IP Logged Quote frontierguy
It's the speedo and all the other guages(meter assy).
Boomer
Posted: Nov 14 2009 at 7:25pm | IP Logged Quote Boomer
Frontierguy, where are you located in PA?  I am in Lancaster, PA.
Boomer
2007 Nissan Frontier SE 4X4
Posted: Nov 18 2009 at 4:48pm | IP Logged Quote frontierguy
Boomer, I'm up north on the border(Stateline Rd) Rome is my mailing address. Between Binghamton and Elmira,NY, just off Rt 17(86).
