Posted: Jan 25 2007 at 10:21pm | IP Logged
God I hate people who do that. NO DO NOT RUN IT AT 80psi.
Nissan put up that pressure for a reason. That's what all your tow ratings and everything stem from, including speedo. Only a full size truck that calls for it would require 80.
The tire even says MAX inflation, not RUN AT THIS PRESSURE! Of course because of our society, people see that 80 and go "Oh, I can run these at 80 psi" That natural pushing things to the limit
BUT... do keep an close eye on the tread. Look for signs of uneven wear. More wear to the inside or outside of edges of the tire will call for an adjustment in pressure.
