Subject Topic: Power steering problem Post ReplyPost New Topic
Monkey Man
Posted: Nov 06 2006 at 6:06pm | IP Logged Quote Monkey Man
I have a 2002 Frontier 4x4 V6 Supercharged and when I first start it up the power steering will not turn to the left but it will turn to the right just fine. It starts turning fine after I drive it about a mile or less. I can't think of what might cause this. Anyone have any suggestions?
Back to Top View Monkey Man's Profile Search for other posts by Monkey Man
Posted: Nov 06 2006 at 11:58pm | IP Logged Quote lakota
Monkey Man;
... Welcome to the Frontier bunch!!
PS fluid gets very hot.  There is a possibility the additives in the power steering fluid are worn out. When the oil is cool it doesn't flow through the valves as well.  Change it out with some new stuff and see how that works out.
Have a good one   and CUL.. Don S..
At home I’m the House Minority Leader
Monkey Man
Posted: Nov 07 2006 at 10:10pm | IP Logged Quote Monkey Man
Is there any easy way to drain the fluid or is a siphon my best bet? Thanks for the help.
hintonl
Posted: Nov 08 2006 at 3:48pm | IP Logged Quote hintonl
What I did was get a turkey baster suck out the old stuff add new. Then start it up cycle the steering a couple of times repeat step 1 till you get it looking clean it will take about 3 or 4 times.
2K Crew Cab Converted to 4X4
Nerve58
U.S. - Kansas
Posted: Nov 08 2006 at 10:19pm | IP Logged Quote Nerve58
I used a large syringe I purchased at a vet supply store, siphoned out as much as I could, and replaced with Lucas power steering fluid.  No problems at all since switch.
Back to Top View Nerve58's Profile Search for other posts by Nerve58
