Subject Topic: Erratic Idle ??? Post ReplyPost New Topic
suckstobeme
Posted: Oct 11 2006 at 7:38pm | IP Logged Quote suckstobeme
Hi guy's , im new to Fronty's as i've wrenched on Honda's until now.
Well on a Honda engine if the idle jumps up and down most likly its the idle air control valve (aicv). Ive swapped those out before. But this 2000 Frontier KK i just bought has me stumped. Ive checked all the vacum lines as well as pulled for any codes on the ECU and found none on either. Any help on this would be great. I'm very anal when it comes to tuning my cars and to have this truck sounding like shat bugs the hell out of me.
Thanks in advance,
Sean
Back to Top View suckstobeme's Profile Search for other posts by suckstobeme
FrontierSC
Posted: Apr 16 2007 at 9:25pm | IP Logged Quote FrontierSC
I had the same problem, have you changed the intake at all, try disconecting the battery and the reconecting it.
Back to Top View FrontierSC's Profile Search for other posts by FrontierSC
lonesomeplayrz
Posted: Apr 17 2007 at 12:10am | IP Logged Quote lonesomeplayrz
bro
try to check your spark plug wires maybe you have a leak. or simple as spark plug loose
Back to Top View lonesomeplayrz's Profile Search for other posts by lonesomeplayrz
CoastGuardZ
U.S. - New York
Posted: Apr 30 2007 at 5:36pm | IP Logged Quote CoastGuardZ
All good suggestions...
Also try spraying the MAFS with a little carb cleaner.  Sometimes they get gunk on them and will improperly read the incoming air, resulting in rough/erratic idle.
Good Luck.
Nate
'07 Frontier CC LB SE 4x4 6spd
'72 Datsun 240Z
'05 Sentra S (SE)
Back to Top View CoastGuardZ's Profile Search for other posts by CoastGuardZ Visit CoastGuardZ's Homepage
chizel
Posted: Jun 15 2007 at 3:41am | IP Logged Quote chizel
Nissan spark plug wires are pretty durable. They aren't a moving part so they don't wear out too often. A careful inspection of your plug wires can avoid any problems.
Back to Top View chizel's Profile Search for other posts by chizel
