TheRedRocket345 Newbie
Posted: Oct 30 2006 at 8:15pm | IP Logged
i believe a 15 in rim can fit, thats what im goin for 15 on 33'' an Superswamper TSL/SX is good set of tires to go w/ ive seen em' in action an do really well offroad. as for the suspension lifts there sorta hard to find, the only ones i found was by calmini they make 2.5 inch and 5 in lift, i been told to go with 5 inch because of the uv joints on 05 an up. the 2.5 pushes em' down an was told that will decrease the life of the joints, the 5 inch gives you straight uv joints like they are stock. jus a friendly suggestion. also i hear that rancho is makin one.
