Posted: Oct 09 2006 at 3:29pm | IP Logged
My truck was already pre-wired from the factory. If you have power windows and locks, yours should be pre wired also. (I personally think that they are all pre wired because it would take too much time to wire each truck based on its particular options). You have the same truck that I have(02 XE), look behind the radiator and locate the headlight harness, there should be a spare plug taped to the headlight harness. If it is, everything else is easy. First go to Pinnacle Nissans website(http://www.allnissanparts.net), click on the "products" tab, then click on "Nissan service parts catalog", on the next page in box "B", enter 2004 for the year and Nissan for the make. You enter 2004, because the 04 fog lights are $65.00 each and the 02 fog lights are $140.00. I don't know why, but but they are. the housings are the same, but the bulbs are different. I will give you a list of part numbers at the end. You will also need to order a new turn signal switch that has the fog light ring on it. It is $52.00 and it takes about 5 minutes to install. One minor problem is that the existing plugs on your truck will not work on the bulbs that come with the 04 lights. You will need to change the pigtail(plug). I bought the pigtails from a parts house that deals in some OE parts for $35.00. However, the plugs have a GM part number so you can get them at any Chevy or GMC dealership. Nissan only sells the entire headlight harness(200.00). After everything is said and done, I spent $227.00 getting factory fog lights, but I prefer the factory look so I did not mind. Here is a list of part numbers and where I got them from.
Item &n bsp; &n bsp; &n bsp; Part Number Cost &n bsp; Where Purchased
Fog Light(r) 26150-1z800 & nbsp; $65.26 & nbsp; Pinnacle Nissan
Fog Light(L) 26155-1z800 & nbsp; $65.26 Pinnacle Nissan
Turn Signal w/fog lights 25540-5m001 & nbsp; $52.00 Pinnacle Nissan
Connector GM 12102664 &nbs p; $16.45 &nbs p;Any GM dealer
I actually finished installing mine today, I had to wait for another connector. I spent a total of about 30 minutes installing it all and it looks great. No difference an mine and what comes from the factory.
Hope this helps, let me know how it goes if you decide to get them. If you can't find the connectors, email me and I will get you the number for the place where I bought mine.
