Subject Topic: AC only works on high Post ReplyPost New Topic
jbfan84
Posted: Aug 29 2006 at 8:47am | IP Logged Quote jbfan84
I have a 2001 Nissan Frontier and the AC has lately only worked on the highest level and not the lower three. anyone know anything? thanks
Back to Top View jbfan84's Profile Search for other posts by jbfan84
rick_dallas
Posted: Sep 15 2006 at 10:15pm | IP Logged Quote rick_dallas
Can't tell you for sure on your truck but in years past, there was two fuses for the blower motor.
One was for the circuit for the lower speeds and the second fuse was a separate, higher amp fuse that was for the high speed only.
Could be that you just have a blown fuse that controls the lower speed settings.
Back to Top View rick_dallas's Profile Search for other posts by rick_dallas
Posted: Sep 16 2006 at 10:18am | IP Logged Quote kcidmil
Easy way to find out.  Does the blower only work on high for ALL settings (ie Defrost, vent, AC)... or just the AC?
If the blower doesn't work at all on the lower settings, either the fuse... though most systems just use one fuse... or your resistor block is blown.
chuckfrontier06
Posted: Sep 17 2006 at 9:00pm | IP Logged Quote chuckfrontier06
There's a100% chance that the fan motor resistor is bad.
Back to Top View chuckfrontier06's Profile Search for other posts by chuckfrontier06
Ventana
Posted: Sep 18 2006 at 10:12am | IP Logged Quote Ventana
Same thing happened to both our Nissan Altima and Nissan Frontier.  As stated in another reply it is the fan motor resistor.  In Canada it cost $100 to have them replaced.
Back to Top View Ventana's Profile Search for other posts by Ventana
