Moe1969 Newbie
Posted: Sep 18 2019 at 6:58am | IP Logged
I have a 98 Frontier 4cyl. Last night on the way
home it started acting up. It idles fine and runs
well until I apply heavy fue(try to engage passing
gear). Any ideas? I did fill up yesterday
afternoon, but I put approximately 40 miles on it
before the issue came up.
__________________ Moe
Posted: Sep 20 2019 at 2:11pm | IP Logged
The only fuel problem I had was water in the gas when I fueled up. I got about 14 miles before the problems and made in back home after work to drain the tank a little then put in an additive for water. there was one quart of water all together.
Good Luck.. Don S..
Posted: Sep 22 2019 at 5:05pm | IP Logged
Might want to replace your fuel filter.
