Subject Topic: PURGE VOLUME SOLENOID Post ReplyPost New Topic
Aris
U.S. - Maryland
Posted: Apr 12 2017 at 6:12pm | IP Logged Quote Aris
can a solenoid purge valve test out ok and still be
bad.what else could cause p1444 on a 2004 frontier 2.4 L
Back to Top View Aris's Profile Search for other posts by Aris
Posted: Apr 16 2017 at 5:47pm | IP Logged Quote frontierguy
It can be working mechanically but leaking vacuum.
Aris
U.S. - Maryland
Posted: Apr 17 2017 at 3:30am | IP Logged Quote Aris
Thanks for the response. I put 15 inches
of vacuum and it held for until I put 12
volts across the coil. A local dealership
gave me the complete diagnostic series .
Basically, that code , even though it
specifically directs you to the solenoid
valve, it could be any part of the vapor
recovery system and you have to test ALL
of the individual parts, unless you just
have extra money to throw parts at it.
Aris
U.S. - Maryland
Posted: Apr 17 2017 at 3:33am | IP Logged Quote Aris
I will send out a message when I get it
figured out so that nobody gets baffled
if they get stuck with this.
