Subject Topic: Leaking while raining Post ReplyPost New Topic
timmymiller
U.S. - Georgia
Posted: May 05 2015 at 8:10pm | IP Logged Quote timmymiller
Has anyone had an issue that some water will leak either by the back window or towards the passanger door? Took to a body shop and they stated it was a panal behind the rear seat Model 2011 Crew cab Thanks Tim
GOD BLESS THE 343 THAT GAVE ALL
Back to Top View timmymiller's Profile Search for other posts by timmymiller
Rubble
Posted: May 06 2015 at 10:15pm | IP Logged Quote Rubble
Probably best to take it to Nissan, cause they probably have more experience.
I've heard of leak's coming in from the Roof top @ the Black Plastic part's @ the Rear,  from the Cab Brake Light assembly, from the Satelite Antenna on the Roof, and also from the Door Rubber Seal's on the high side.
A leak can be somewhat difficult to find,, cause the water may run and come out @ a diferent location.
Best to take it to people with Nissan Experience I think.
Good Luck
Barney
